Different workflow for different issuetypes
Madhura A S
Hi experts,
When we create a project default workflow will be created for all issuetypes in Jira and Project Admin can edit this. But They do not have permission to create new workflow and add it to Workflow scheme.
Our requirement is to assign different workflow for each issuetypes on project creation so that project admin can modify the workflow as they want.
Is it possible to do in Jira? If yes, Please guide me how i can achieve this?
Madhura
Yogesh Mude
May 29, 2018
Hi @Madhura A
For all these tasks you need jira administrator rights.
First, create workflows as you have the process and then create Workflow scheme.
Once you are done with workflow scheme then edit it and add the workflows to this workflow scheme and then associate with each issue type.
Apply this workflow scheme to the project.
For more information about creating workflow and workflow scheme please visit the below articles.
https://confluence.atlassian.com/jira060/configuring-workflow-370705895.html#ConfiguringWorkflow-Creatingaworkflow
https://confluence.atlassian.com/adminjiraserver071/configuring-workflow-schemes-802592719.html
Madhura A S
Thanks for the Reply. But My requirement is to have the different workflow for different issues when we are creating the project. Capture.PNGThis is the default workflow that we will get when we create the project and this is assigned to all the unassigned issuetypes. Can we have separate workflow for bug, task, Subtask....etc. So that Project admins can modify their workflow for issuetypes.
Nic Brough -Adaptavist-
May 29, 2018
Yes, that's what Yogesh wrote about in his answer.
You can't do it when creating a project, it takes a set of defaults.  But the admin creating the project can go straight to "configure project" after getting the "project created" message, and immediately edit the project to apply your workflows
Yogesh Mude
May 29, 2018
HI @Madhura A
There will be two options you have If suppose you want ot create a project with the same configuration as an existing project then whenever you are clicking on Creat project button on the pop up window it will show create with shared configuration using this it will create a project with the same configuration as the existing project have.
Another way is to create a project with default configuration and then associate the Issue type scheme, workflow scheme, Field configuration scheme and all which you want to use.
Yesica Barca
June 10, 2020
Hi, I have two differents workflow, but when I started the Sprint only see one of them. How can I solved this.
In my group we have a workflow for bugs and another for task, subtask, etc.
I been seraching for days but I didn´t find an answer. please help!!
June 10, 2020
Please see the links to "configuring workflow schemes" given above
Praveen
Hi Madhura,
You can do it. Please refer to the below KB.
https://confluence.atlassian.com/jira064/configuring-workflow-schemes-720412604.html
-Praveen
