i am upgrading jira to version 8.19.0.
We use BigPicture and i want to disable the new added advanced roadmap.
Michael
You can deactivate the individual modules of the plugin in the Jira administration.
If you only want to restrict the visibility of the individual settings in the “Manage Apps” section, it is sufficient to deactivate a single module.
Settings > Manage apps > Show "All apps" > filter for "Roadmaps", then: Application components: Advanced Roadmaps for Jira > click "55 of 55 modules enabled" > 'plugins-jira-admin-section-ar': Disable.
Hello Everyone,
I am facing the same issue. I need to hide the Team Field of Plans or at least disable Plans from my DC Jira. any Ideas?
Hello @Michael Kornatzki
Have you try just removing everyone's view permissions or all permissions? Will that work?
G+G > Advanced Roadmaps permissions > update the general permissions.
Resume : Atlassian introduces Advanced Roadmaps in Jira Server, but you need a license (or upgrade to Cloud/Data Center)
Advanced Roadmaps introduced a new Custom field "Team", that is locked, and that conflicts with a custom field we already had.
Advanced Roadmaps cannot be disabled (but you cannot use it without license)
Great job. They completely ignore their Server customers ? (or even worse...?)
Hi Marc,
i saw your answer regarding a script to count linked issuess.
Can you show me the code to show in 1200 issues all issues with only 3 components?
I did not know how to contact you without this comment.
KR
Ibrahim
Hello Michael,
Were you able to find a way to disable Advanced Roadmaps? I'm in the same situation as you and it's frustrating that there's no easy way to do this.
Kamran
No, sadly not
Unless you authorize some user groups, advanced roadmaps is only visible to system administrators.
and that is too much.
We have a few administrators and i want to disable it for all (also for me)
Have you tried Settings -> Manage apps -> Advanced Roadmaps for Jira -> Disable
BR, Olga
Hi Olga,
there is no option to disable the plugin.
Okay, which version of Jira are you using? And are you sure you are using server?
v 8.19.0 DataCenter
Did you catch the news at Team ‘25? With Loom, Confluence, Atlassian Intelligence, & even Jira 👀, you won’t have to worry about taking meeting notes again… unless you want to. Join us to explore the beta & discover a new way to boost meeting productivity.
Register today!Online forums and learning are now in one easy-to-use experience.
