Disable Email Notifications
Darrelle Wood February 20, 2019
Is it possible to disable email notifications and only receive these in JIRA?
I get loads of them and I'd much rather keep them out of my inbox!
Where do i find ‘Project’ option to get to the notification area?
cant find that option on the project
Tansu Akdeniz
I mean the related project (ex: "Atlasssian" below pic) where you want to remove notifications.
Nour Durra _ Consultant February 20, 2019
click Project Settings, and you will be directed to a new set of settings on the left panel, scroll to Notifications
Hi @Darrelle Wood ,
what @Tansu Akdeniz mentioned above is 100% correct, in addition you won't be able to achieve this unless you are a Jira Admin.
Tansu Akdeniz
Hi @Darrelle Wood ,
Welcome to community.
Go to project -> project settings -> notification, than edit notifications depending on issue event.  But it affects all users in that project.
Also please check this KB.
