So I setup LDAP Auth and tested configurations fine. Everything went great, so I logged out and went to log in.
Now I can't log in via LDAP or my local User. It just keeps giving me Captcha's and saying either your not permitted to login, or your login requires a captcha.
I have CLI access to the server, there has got to be a way for me to recovery my JIRA Instance! This is really a HUGE deal to be locked out of Jira. I am 99% sure I didn't disable Local Login, but its below LDAP on the list of methods to use. I cant even log in via my LDAP user anymore, but they don't have admin rights....
How can I disable/delete the LDAP configs from the CLI?
https://confluence.atlassian.com/jira/retrieving-the-jira-administrator-192836.html
Add a new 'localadmin' user with the password sphere:
mysql -uroot -p
use jiradb;
insert into cwd_user values (999999,1,'localadmin','localadmin',1,'2012-01-04 19:49:05-08','2012-01-04 19:49:05-08','local','local','admin','admin','local admin','local admin','localadmin@localadmin.com','localadmin@localadmin.com','uQieO/1CGMUIXXftw3ynrsaYLShI+GTcPS4LdUGWbIusFvHPfUzD7CZvms6yMMvA8I7FViHVEqr6Mj4pCLKAFQ==',NULL,NULL); insert into app_user values(999999,'localadmin','localadmin'); insert into cwd_group(id, group_name, lower_group_name, active, local, created_date, updated_date, description, lower_description, group_type, directory_id) values ( '888888','jira-administrators','jira-administrators',1,0,'2011-03-21 12:20:29','2011-03-21 12:20:29',NULL,NULL,'GROUP',1); insert into cwd_group(id, group_name, lower_group_name, active, local, created_date, updated_date, description, lower_description, group_type, directory_id) values ( '777777','jira-users','jira-users',1,0,'2011-03-21 12:20:29','2011-03-21 12:20:29',NULL,NULL,'GROUP',1); insert into globalpermissionentry (id, permission, group_id) values (555555,'SYSTEM_ADMIN','jira-administrators'); insert into globalpermissionentry (id, permission, group_id) values (444444,'ADMINISTER','jira-administrators'); insert into globalpermissionentry (id, permission, group_id) values (333333,'USE','jira-users'); update cwd_directory set active = 1 where id = 1; flush privileges; quit;
sudo service jira stop && sudo service jira start
This didn't actually disable LDAP, but gave me a localadmin to log in as to do what I needed in the WebGUI like disable LDAP and change users etc etc.
You have missed couple of query, due to which when you'll try to login, it'll throw an error:
You do not have a permission to log in. If you think this is incorrect, please contact your Jira administrators.
insert into cwd_membership values (666666,888888,999999,'GROUP_USER','','jira-administrators','jira-administrators','localadmin','localadmin',1);
insert into cwd_membership values (555555,777777,999999,'GROUP_USER','','jira-users','jira-users','localadmin','localadmin',1);
ต้องการยารักษาแค่ไหนก็บอกหมดนะครับแต่อาจจะจึดไปนะครับคือมันหน้าจะแรงกว่านี้ครับได้ผสมได้อาจจะนะครับคือมันติดยากอะครับทุกคนมีข้อคิดเห็นยังไงก็บอกหมอเค้านะ ครับใหญ่หรือเล็กจะไปก็ไปครับ มาก็มาดิมาดิมาดิมานี้ครับอารมย์ไม่จำเป็นต้องดีในวันนี้แม้ไม่มีใครติดต่อมาเลยครับ ปม้งเลยขาดยาหรอกมั้ง
