In BigPicture it is possible to delete issues. These issues can not be restored.
Is it possible to the disable the function to delete issues in BigPicture? If yes, which steps should be followed?
Thank you!
Hi Andrei,
To my knowledge this right is managed only on Jira project side.
So you have to be sure that the users are not part of any role granted with delete issue access on the Jira projects of your scope.
I hope it helps.
