Does anyone know if there is a way to disable the ability for end users to select the "Hide unused fields when creating issues" labs option in their Jira personal settings? There are some request forms we've created for Jira projects where the fields should always appear in the order we've specified, even if a response is not required. Some users have this turned on and it hides the fields that they don't fill out often. Is there a way to prevent this from being enabled?
Hello @Ylan Muller
That option does not appear to be available, but there is a change request about it to which you can add your vote/comments.
