Hi
I have a kanban board with different collumns which I use to plan my tasks. Suddendly today when I move a task from "this week" to "today" there is some kind of automatic sorting. I wanna place the tasks manually in the ordre I want them in the "today" collumn but this is not anymore possible. Is there a new feature toggle that I need to turn off in orden to manually place the tasks as I want them in a collumn?
I use a Kanban board with different columns to plan my tasks. Today, I noticed that when I move a task from the "This Week" column to the "Today" column, the tasks are automatically sorted. I prefer to arrange the tasks manually in the "Today" column, but this no longer seems possible.
Is there a new feature or setting I need to disable to regain the ability to manually organize tasks within a column?
it's a team managed one and a software project. After playing with it I thing it is a refresh issue. Once I move a task from one column to another the gets automatically moved to the bottom. But if I refresh the browser og move another task then it previous task is placed in the ordre that I moved it to. Very weird since I have changed nothing in the settings and it happens on two different browsers and to different computers. So a workaround is to move a task - refresh the browser and then it is placed in the order I want the task to be.
Is this a company or team managed project? Is this a software or work management project? When you say the are automatically sorted can you interpret the "sort by" results?
it's a team managed one and a software project. Have a hard time understanding how the priority is done - it is not due date and not priority
once the task is moved to new column and it gets automatically sorted, then the next time I move its rank in the column manually it stays in the sort of my choosing.. Very weird and it started late today and I have not made any changes in settings etc...
Also if a move task from one column to another and place it at the bottom it gets automatically moved to top. But then if I refresh the browser it is back to the spot where I moved it to.
