Disabling "Post Upgrade Landing Page"
Daniel Ebers
October 6, 2020
Hi Community,
for several reasons we'd like to disable the "Post Upgrade Landing Page" (PULP) in Jira (v8.5) which is presented after Upgrades.
In Jira I found a system-related addon that indeed "could" be disabled.
Simple question before testing it on a non-production environment:
has somebody here already disabled the Post Upgrade Landing page addon without facing any inconsistency problems or any failing dependencies/negative effects of whatever sort?
Funny finding: for some Confluence versions there is some dark feature documented ("-Datlassian.darkfeature.pulp.disable=true") in order to disable the feature.
Thanks a lot!
Daniel
Laurent Delplanque January 15, 2025
Hi Daniel,  Did you applied this workaround successfully ?
We have the exact same issue and https://jira.atlassian.com/browse/JRASERVER-72521 is unlikely to be done one day :(
Regards
Laurent
Daniel Ebers
January 15, 2025
Hi @Laurent Delplanque
yes - it's fixed for my installation.
Inserting Dark Feature "com.atlassian.jira.pulp.disabled" did the job.
Learn more about it here:
Daniel
Wonderful, many thanks Daniel, you made my day :D
