Hi!
I've been trying to display Goals in my JIRA Cards as I could do with other fields. Note that I've been modifiying the Settings like I did plenty of times in the past with others.
As you can see in the images below, apparently everything is configured correctly.
Am I doing something wrong?
Hi @Nacho Cortes,
I suspect that displaying Goals on board cards is not yet supported somehow. And by that, I just mean the visualisation part of this. I have simulated your scenario in a test instance of mine and I can confirm that I see the exact same behaviour.
I don't find a suggestion or bug in the public backlog for this (yet), so it might be an idea raising a support request for this with Atlassian directly.
Hope this helps!
Hi Walter!
Thank you for testing this one also. You know it would be awesome if people could easily see the link between their daily work with big strategic objectives.
Hopefully displaying this in JIRA Cards will be available asap.
Thanks again!
