We use Scrum and Kanban Agile boards in JIRA Data Center for team project work. We also use the Google Jamboard whiteboard app to display and collaborate with teams across company wide JIRA issues. The obvious issue is that we do our work in JIRA but have to *manually* create and organize separate "JIRA stickers" for the Jamboard.
Is there a recommended app or JIRA process that will simply merge a set of team boards to display the company wide picture like Jamboards at the team level?
You could use Jira dashboards. They can be customized by using the gadgets offered by Jira and 3rd party apps, like our Great Gadgets app.
In addition, they support wallboard mode and wallboard slide-show, so you can display them on TV screens in the open space and use them as information radiators.
See this article on our blog, with examples of dashboard for each team and a cross-teams dashboard: How to track multi-team or scaled-agile projects (such as SAFe®) in Jira with Great Gadgets app
I hope this helps.
Danut.
Yes thanks! Your helpful Dashboard reporting suggestions provide ideas that I had not considered before! Also, our recent JIRA 9.4.9 upgrade may help us leverage our JIRA data across teams with JIRA Advanced Roadmaps and features like top level company-wide initiatives that can drill down to the sub-task level. Lot's of work to do...
