Sign up Log in
Display custom field value from a jql result in jira cloud
AbrahamA
May 3, 2023
Hello
Do you have a script sample to display custom field value from each issue of jql search result.
Can you please give some pointers.
Abe
Nic Brough -Adaptavist-
May 4, 2023
This script does most of what you need - https://library.adaptavist.com/entity/calculate-sum-of-fields?tab=cloud
You will need to replace the "find issues from their parent issues" with your JQL search, but the rest of it should work find for you.
Jack Brickey
May 3, 2023
Hi @AbrahamA , I'm guessing that you want something different than simply a JQL statement that presents a list of issues and that list includes a column for your custom field? I'm not quite sure what you're asking for here. Maybe you could elaborate?
AbrahamA
May 3, 2023
Helo Jack
Thanks for the response
I need to sum values in a particular custom field for all issues that match a condition. This is my requirement.
Abe
Jack Brickey
May 3, 2023
I would export to Excel and sum. The official extension for excel would make it easy to do this too. In case you prefer Google apps - jira-cloud-for-google-sheets-official
AbrahamA
May 3, 2023
I have scriptrunner, so I am looking for script route
Jack Brickey
May 4, 2023
I see. I have added "Scriptrunner" tag to your post.
