Display field according to the result of two other fields
l
Hi Team, I'm using script runner to get multiplication result of two fields in another fields (Riskrate)and to categorize the result in Riskrate to High,medium,low. For the same I have created the beklow script. But not completely functional. Please help
def selecta= getFieldById("customfield_17796")
def selectb= getFieldById("customfield_23399")
def risk= getFieldById("customfield_28038")
def TestBed = getFieldById("customfield_26609")
long selectaVal = ((selecta.value ?: "0") as String).toLong()
long selectbVal = ((selectb.value ?: "0") as String).toLong()
risk.setFormValue(selectaVal * selectbVal)
long selectaValnew = ((selecta.value ?: "0") as String).toLong()
long selectbValnew = ((selectb.value ?: "0") as String).toLong()
long RiskrateVal = ((risk.value ?: "0") as String).toLong()
if(RiskrateVal <= 9)
if(RiskrateVal > 5)
{ TestBed.setFormValue("Medium") }
else
{ TestBed.setFormValue("Low") }
else
{ TestBed.setFormValue("High") }
@com.onresolve.jira.groovy.groovyrunner
JohnsonHoward
April 4, 2017 edited
Try adding the following code to a scripted field named "Risk Rate":
Issue mainIssue = issue
def impact = customFieldManager.getCustomFieldObjectByName("Impact")
def probability = customFieldManager.getCustomFieldObjectByName("Probability")
def impactVal = mainIssue.getCustomFieldValue(impact).toString().toInteger()
def probabilityVal = mainIssue.getCustomFieldValue(probability).toString().toInteger()
def overallRating = (impactVal * probabilityVal)
def result = ""
switch (overallRating) {
case { overallRating < 5}:
result = 'Low'
break
case {overallRating >= 5 && overallRating <= 9}:
result = 'Medium'
break
case {overallRating > 9}:
result = 'High'
break
default:
result = 'N/A'
break
return result;
You will have to change the names to match your field names and the case values to your preference. I have made the assumption here that the custom fields are text fields, so I casted them to string then to int. You will not need to do this is the field values are already numbers.
Also, if you would like both a risk rate numerical field and a text field then you will need to add a second scripted field and just return the 'overallRating' value instead of using the switch statement.
Take a look at this for more info on scripted fields: https://scriptrunner.adaptavist.com/latest/jira/scripted-fields.html
JohnsonHoward
April 18, 2017
Did this solve your problem?
Johnson Howard
l
Any update???
l
customfield_17796 and customfield_23399 are select list and customfield_28038 is number field and customfield_26609 is a text field
Thanos Batagiannis [Adaptavist]
January 11, 2017
and what about customfield_28038, customfield_26609 ?
l
yes, these are select lists
January 11, 2017
What type are the custom fields customfield_28038, customfield_26609 ? I suppose the customfield_17796 and customfield_23399 are select lists (single choice) .
