Display parent Fix Version on sub-task screens
Kelley Cooper
Have read many posts about Fix Version and Sub-tasks but don't think I've seen one which answers this question:
Can I display the parent's Fix Version value on its child Sub-task screens as a read-only value?
Can I accomplish this with ScriptRunner and a scripted field?
I understand I can use post-functions, etc, to set the Sub-task's Fix Version to the same as the parent BUT there are always holes in that process; I'd rather just display as read-only on the Sub-task screens its parent's Fix Version.
Thank you in advance for any help!
Antoine Berry
Hello @Kelley Cooper ,
You are absolutely right, you should use a script field in that case. This is how I did it :
with the code :
if (issue.isSubTask()){
    return issue.getParentObject()?.getFixVersions()
This is how it appears on the view screen :
Kelley Cooper
Thank you so much, @Antoine Berry !!
