Display the Reporter field in the ticket view
Tristan Pouliquen September 16, 2021
For our bug monitoring view (we use Kanban boards), I would like to display the "Reporter" field so the developers know who to contact for further details easily.
However, I cannot manage to display it in the view.
I have added it in my Screen configuration:
And tried to customise its disposition:
But when I open the issue, I do not see anything:
When I look in my Issues explorer, I see that all the "Reporter" fields are marked as "Unassigned" :
Does anyone have an idea on what's going on? Permission issue (I'm a JIRA admin on this platform but maybe I missed something?)? Other?
Tristan Pouliquen September 17, 2021
In the Default field configuration of my organization, the "Reporter" field was tagged as hidden, which was the cause of my problem. :-)
Jack Brickey
Ah yep that would do it.
Jack Brickey
The reporter field should be there OOTB. How are the issues being created (portal, email, Create button). The fact that it shows not assigned tells me that it is not getting filled in at creation which is rather odd as that should be automatic. It would be interesting if you created a test issue to see if you are listed as the Reporter.
Jack Brickey
Also do all issues have not assigned in the Reporter field?
Tristan Pouliquen September 16, 2021 edited
I create them from the "Create" button".
And yes, no issues have any value in the "Reporter" field :/
The issue on the screenshot is a test issue I've just created.
Jack Brickey
First I generally recommend against using the create button. The reason for this is that some things can get missed such as the request type which is important if you want customers to be able to view an issue in the portal. Rather as an agent, use the raise request button.
with that said, when you do create an issue on behalf of a customer you should see the following. If yo do not change it the you, as the creator, will be the reporter.
please share what you are seeing. Is it possible that someone created a custom field called “reporter” resulting in this issue?
I do not have a "Raise request" button in my view:
I see that this tool added tags as "jira-service-desk-cloud".
We only use the Jira Software Cloud I think
Jack Brickey
Ok hold on. This post is under the JSM collection so I think we are off track here. Looking at your image it appears that indeed this is a SW project. So forget all of the previous input and let’s reset.
The one bit of previous input that should still apply is that the Reporter should be there by default. That is, when created, an issue will have the Reporter set to who created the issue. It makes no sense that this field would be empty unless there was some automation that clears the field. While this would be very strange I would certainly check that. I would be interested in whether this happens on other projects.
Hum, sadly no automation rule mingles with the Reporter field (either on the project or the global level), or it's a secret one!
I agree that this field should appear & fill itself automatically!
Thank you for your time!
Jack Brickey
I recommend reaching out to Atlassian support. I’ve never seen this field not be populated at creation. So if you don’t have a custom field called reporter that could explain things then something else is amiss.
Will do! thank you again!
Jack Brickey
Report back here when you get closure if you don’t mind.
Learn more
