×When displaying an issue, JIRA also shows all sub-tasks that are linked to the issue under the Sub-Tasks tab on the issue display screen.
However, important information like the original estimate at the individual sub-task level is not displayed.
Is there any way to add this column to the display of the sub-task info on the issue display screen?
Thanks for advising.
I raised a ticket after which the support department did something in my onDemand environment after which the original estimates nicely appear.
Thanks guys !
According to this documentation, you can add the column "timeoriginalestimate" from IssueFieldConstants into jira.table.cols.subtasks property
It does not!
Please refer to your documentation: https://confluence.atlassian.com/display/JIRA/Advanced+JIRA+Configuration
It should be working. If its not, please report it to the support team https://support.atlassian.com/browse/JST
ira.table.cols.subtasks property is on of the property that can be edited in JIRA Administration > General Configuration > Advanced Settings. Those that can't be edited will require the user to create the property file.
In onDemand there is no path JIRA Administration > General Configuration > Advanced Settings.
... Subsequently I don't have a clue what you are refering to.
Sorry for my mistake. I have just confirmed with the onDemand team that Advanced setting page is restricted to our support team only. You will need to raise a ticket to change the setting https://support.atlassian.com/browse/JST
