Our company is an small one where each member works in several projects at the same time.
The "Assigned to Me" Gadget (for Dashboards) is cool but this is a list of all task:
- Task 1
- Task 2
- Task 3
- Task 4
Is it possible to group this list by projects?
For example:
Project 1:
- Task 2
- Task 4
Project 4:
- Task 1
- Task 3
Thanks a lot of!
You could create separate search filters for issues assigned to you within each project. From there, you can display the "Filter Results" gadget for each separate filter. This way you will display each project separate from eachother.
mmm... I'd like a more automatic way.
A lot of work for all my projects.
Anyway I do it as you said
Hey, you could use the two-dimensional filter statistics gadget or display the project as a column in your filter.4..
Cheers Christian
Thanks Christian,
The 2-dimensional is cool to count, I want is a list of issues.
Any other ideas?
