Docker atlassian/jira-software can not be upgraded from 8.20.6 to 8.21+
zoltan_zvara
I started Jira with the following `docker` command:
docker run -d -e JVM_MINIMUM_MEMORY=6144m -e JVM_MAXIMUM_MEMORY=6144m -e JVM_RESERVED_CODE_CACHE_SIZE=2048m -e ATL_PROXY_NAME="jira.example.com" -e ATL_PROXY_PORT="443" -e ATL_TOMCAT_SCHEME="https" -e ATL_TOMCAT_SECURE="true" --name jira.atlassian.sys.alpha --hostname jira.atlassian.sys.alpha --network-alias jira.atlassian.sys.alpha --network system --volume jira.atlassian.system:/var/atlassian/application-data/jira atlassian/jira-software:8.20.6
In order to upgrade this installation, I did the following:
`docker rm -f jira.atlassian.sys.alpha` then
docker run -d -e RUN_GROUP=root -e RUN_UID=0 -e RUN_USER=root -e JVM_MINIMUM_MEMORY=6144m -e JVM_MAXIMUM_MEMORY=6144m -e JVM_RESERVED_CODE_CACHE_SIZE=2048m -e ATL_PROXY_NAME="jira.example.com" -e ATL_PROXY_PORT="443" -e ATL_TOMCAT_SCHEME="https" -e ATL_TOMCAT_SECURE="true" --name jira.atlassian.sys.alpha --hostname jira.atlassian.sys.alpha --network-alias jira.atlassian.sys.alpha --network system --volume jira.atlassian.system:/var/atlassian/application-data/jira atlassian/jira-software:8.22.4
The only change is the version from 8.20.6 to 8.22.4.
The error is the following:
INFO:root:Generating /etc/container_id from template container_id.j2
INFO:root:Generating /opt/atlassian/jira/conf/server.xml from template server.xml.j2
INFO:root:Generating /opt/atlassian/jira/atlassian-jira/WEB-INF/classes/seraph-config.xml from template seraph-config.xml.j2
INFO:root:/var/atlassian/application-data/jira/dbconfig.xml exists; skipping.
INFO:root:User is currently root. Will downgrade run user to root
INFO:root:Running Jira with command '/opt/atlassian/jira/bin/start-jira.sh', arguments ['/opt/atlassian/jira/bin/start-jira.sh', '-fg']
executing as current user
Cannot find /opt/atlassian/jira/bin/setclasspath.sh
This file is needed to run this program
The above error is present even if I change `RUN_USER=root`, `RUN_GROUP=root` or `RUN_PID=0`. Checking the contents of the image I can see that the `/opt/atlassian/jira/bin/setclasspath.sh` is there.
This issue is critical to us because we can not upgrade as advised because of a vulnerability.
zoltan_zvara
I upgraded from `docker-ce` 18.06.X on Ubuntu 18.04 LTS to `docker-ce` 20.10.X and then it worked. It was a Docker or `containerd` issue.
Thiago Masutti
July 4, 2022
As some mentioned on the thread, please update the Docker Engine to the latest version.
You may find more details on https://confluence.atlassian.com/kb/running-atlassian-products-on-docker-might-fail-during-startup-because-of-docker-engine-version-1141492018.html
Thiago Masutti
Benjamin Dombrowsky June 30, 2022
in my case it was obviously related to an old Docker version. I updated docker and the image/jira is now running.
BR
Benjamin
I think there is a general problem with the newest docker image(s).
I'm getting the error with both Jira and Confluence in the latest Docker Image version.
Unfortunately I don't have a solution at the moment.
BR
Benjamin
Juan Ramón Alonso
July 7, 2022
A good practice before upgrading is always first take look at the docs, just in case something has changed. Just go to https://hub.docker.com/r/atlassian/jira-software and you will see that now docker engine >= 20.10.9 is required. As mentioned above, that will resolve the issue.
Arthur
July 5, 2022
Thanks, that also solved the problem for us:)
Lars Ackermann
July 3, 2022
Just went through the upgrade procedure in our environment. Indeed after getting Docker 20.10, it worked. Thx for the hint!
zoltan_zvara
Try updating the Docker engine, it worked for a few users.
Lars Ackermann
July 1, 2022
Same for me: setclasspath.sh is inside the container, r-x access rights set but cannot be found/used during startup.
Please correct the latest docker images, our Jira/Confluence is down after trying to upgrade for the sake of the latest security advice.
zoltan_zvara
Which Docker did you have?
Benjamin Dombrowsky July 1, 2022
Yes, I've the same behaviour in different systems. For me a docker update resolved this issue.
Daniel Hilgarth July 1, 2022
Helped me as well
Arthur
July 1, 2022
Having the same problem since today. But we didnt even change the docker images. We just restartet the containers and then got these errors.
