Documention our Jira
Dąbrowski Damian May 20, 2024
Hi Awesome People,
I am looking solution which help me create documention about my projects, workflows, scheme etc. Everyhting about our instance Jira.  How work with this ?
Damian
Mayank_FastDoc
Hi Dąbrowski,
If you're looking for a solution to generate internal or customer-facing documents like release notes, user guides, or help articles directly from Jira, FastDoc could be a great fit. This add-on simplifies the process by pulling information from Jira tickets, JQL, or Releases, saving you time and effort. You can also use templates and seamlessly publish the documents to Confluence.
Let me know if you'd like to explore this further!
Matt Parks
May 20, 2024
Jira is not a great place to store documentation, so you will need to use another application for that. If you're using Confluence in addition to Jira, I would recommend using that as a place to store your documentation.
