Does JIRA on the Fly (Checklist) collect data?
William Pettersson
October 28, 2024 edited
I am considering using Jira on the Fly (checklist).  As part of our due diligence I was wondering if anyone knows if the plug-in has the ability to collect data.  This plug-in is a download from the Atlassian marketplace.  I just wanted to make sure that the data stays within JIRA only and the vendor does not have access to that.  Thanks
Mikael Sandberg
If you check the Marketplace listing for the app and the Privacy & Security tab it is stated that the app does not process end-user data outside of the Atlassian product, so that would mean that the data stays within Jira.
William Pettersson
Thanks for the info.
Like • Mikael Sandberg likes this
William Pettersson
Quick question.  I found the Privacy & Security tab.  Do you know if that statement regarding 'app does not process end-user data outside of Atlassian' is input from the vendor or Atlassian?
Mikael Sandberg
That is from the vendor, Atlassian has a privacy and security questionnaire that the vendor can fill out and this what is being used for the Marketplace listing.
Like • William Pettersson likes this
