Does Jira Work Management (Cloud) support "Versions"
Giampiero Celluprica
My team (500 users) is currently using Jira Core (Server) and we are now evaluating the migration to Jira Work Management (Cloud).
We add the "Versions" to our Jira projects to use them in the "Affects Version/s" and "Fix Version/s" fields of the issues we raise.
From what is written at https://support.atlassian.com/jira-work-management/docs/view-and-manage-a-projects-versions/ looks like the "Versions" are supported in Jira Work Management as well, but I would need to be 100% sure.
Could you please confirm that Jira Work Management (Cloud) actually supports "Versions"?
Patricia Francezi
October 28, 2022
Hi @Giampiero Celluprica
I confirm the version configuration is available for Jira Work Management projects.
You can rely on the doc you already mentioned in your post to configure it
I hope this helps
Thanks Patricia for confirming!
Like John Funk likes this
