Does anyone know how to unlock to configure the standard Jira fields CLOUD?
Angela Boston
I would like to configure the Team field.  I've been unsuccessful finding info on how to unlock.  Looks like there is a help page for Server, but we are on Cloud.
Also, I'm unsuccessful finding a list of Standard (out-of-the-box) fields in Admin at all.  I find Team because I knew it was there and that was from Search in Field Config I believe.
Any advice?
Matt Doar
https://confluence.atlassian.com/jirakb/how-to-unlock-a-locked-field-779158866.html says "These fields are locked to prevent accidental changes which can subsequently break the operation of JIRA Software"
I'm not sure why you want to change the Team field, but it's not a good idea for long-term maintenance in Cloud or Server
Angela Boston
I'm ignorant to the purpose of the field then.  My goal was to configure to add values for the uses to select.  Do you know the purpose of the field?
Nic Brough -Adaptavist-
October 18, 2018
It's a field set by an App, it will populate naturally when you use the functions of that App.  Tempo is my guess, unless you have Portfolio.
Unlocking it would not let you add values anyway, you have to go through the App.
Angela Boston
Got it.  We had Portfolio for a while.  Makes sense.  I will create  custom field.  Thank you
