Hi All,
Once completing a sprint, any open issues that are assigned to the sprint, auto moves to the next sprint or the backlog.
In JIRA 7, i see that this procedure does not clear the Sprint field from the issue itself, and if i query on the sprint, i see the list of open issues as part of it, althogh it is now part of the backlog or the next sprint.
I guess that the logic is that even though the sprint is closed and issues are removed from it, i would like to easily see which issues were committed and incomplete in the closed sprint.
Do i understand correctly? Would like to get clarifications on this,
Shirley
You understand it correctly - it's retaining the sprint data from previous sprints because they're needed in order to do the numbers and report on the committed/incomplete.
Was this ALWAYS the case? I feel like it wasn't always this way.
This is forcing me to re-think Filters & Dashboards that I use to track based on Sprint, because the Sprint field will often have multiple values even if it was properly moved.
I do see the following in the Sprint Report in the Agile Board:
My JIRA system info:
...and actually, even if you remove the completed sprint from the JIRA issue, it is STILL retained in the "Issues Not Completed this Sprint" so I don't think this really makes sense...
