Does the Previous Project Key field still exist?
Elly Hyam-Hobden
December 10, 2024
Hi There,
I am wanting to re-use a project key in a new project.
I have found in this article:
https://support.atlassian.com/jira-work-management/docs/edit-a-projects-details/
Reference to being able to do this, by changing the project key, and then deleting the previous project key :
In the Previous project keys field, delete the relevant project key.
When I navigate to the project settings, I am unable to see this field.
I have a specific use case for doing this, related to the recent change around maximum field entries in Jira Issues.
3 votes
Trudy Claspill
Hello @Elly Hyam-Hobden
According to the weekly blog, that feature is still being rolled out. It may not yet have been applied to your instance.
https://confluence.atlassian.com/cloud/blog/2024/12/atlassian-cloud-changes-dec-2-to-dec-9-2024
Search the above for "project keys".
Trudy Claspill
You're welcome!
If your question has been adequately addressed, please consider clicking the Accept Answer button to mark your Question as Solved.
Elly Hyam-Hobden
December 10, 2024
Wow that is super helpful thanks @Trudy Claspill !!
