×Hi guys,
I was looking in the list of releases we have in one of our project and found out that sorting works a bit wonky.
I have sorted the releases manually in the project release pane, and that translates well for the FixVersions dropdown field on a specific issue.
On the other hand, Affects Versions drop down menu on the same issue has completely unlogical sorting, partly it follows the fixversions, but there are some unreleased releases positioned in a completely unexpected positions in drop down menu.
Start and release date don't play any role as far as i see, nor the number of issues or progress bar.
Does anyone have any idea on how the sort works for those two dropdowns?
There are several defects and suggestions around the sorting in those fields, with some of them over a decade old, such as this one: https://jira.atlassian.com/browse/JRACLOUD-42225
My understanding of the current behavior (although I have not tested it recently) is to show:
Still nobody found a logical explanantion on the field sorting behaviour?
