Due Date Automation
Barış Özer
hello everyone,
In a project, we want to send an e-mail to the person assigned to the assignee 7 days before the due date in each ticket. And I want an e-mail to be sent to an e-mail address I want.
1 day after the due date expires, I want to send an e-mail to the assigne and to the e-mail address I want.
Need JQL?
Or can I do it with Automation?
I ask for your help.
Best regards.
2 accepted
Tauwa
Here is the solution:
  • Filter Subscription:
    • Requirement1: 7 days before due date
      • Create a JQL Filter
        due < 7d and due > now() and assignee = currentUser()
      • Create a subscription to all your users but you have to identify the group. You can select a group where all your users are. Don't worry the email will be sent only to the assignee. You can send this on a daily basis for example (or choose what you want)
    • Requirement2: 1 day after due date expires
        due = -1d and assignee = currentUser()
      • same as before. Notice though that with filter subscriptions you WILL NOT be able to use a public email address.
  • Automation: will do the same and even more. Because you will be able to send emails to a public email address
Hope it helps.
Tauwa
Barış Özer
First of all, thank you very much.
In the screenshot you took about Automation;
An e-mail will be sent to the assigne person 7 days before the due date.
1 day after the due date, an e-mail will be sent to the e-mail address I want, is it true?
Does the JQL you wrote work for this?
Barış Özer
Can you share the rule details with a step-by-step screenshot?
If:matches then I can't find what to do.
Barış Özer
@Tauwa
I did as you showed.
7 days ago the notification will go and after 1 day the notification will be gone, is it true?
Tauwa
Yes it is OK. Don't forget to accept the answer plz.
cheers
Barış Özer
@Tauwa
I fixed the JQL code as below;
(due < 7d and due >=now()) OR (due > -1d)
Is it correct?
regards
Barış Özer
@Tauwa
It started working correctly with this code.
But there is no ticket number in the content of the e-mail. How can we write?
Thx
Tauwa
Barış Özer
@Tauwa
Where exactly do I need to write the smart value? To the content of the mail?
Can you post a screenshot example please?
Barış Özer
@Tauwa
I did it with issuekey,
Can we put the related issue as a link?
Barış Özer
@Tauwa
I did it, thanks a lot for your support (:
Best regards.
Like Tauwa likes this
Tauwa
Great. You are an Automation Pro now :)
Like Barış Özer likes this
Barış Özer
@Tauwa
Hello again,
Although there is a due date of August 1, the mail notification is gone.
Since the ticket has passed for 1 day, can you help me where am I doing wrong?
Tauwa
due < -1d NOT due > -1d
Barış Özer
@Tauwa Hi,
(due < 7d and due >=now()) due < -1d NOT due > -1d
I don't understand what exactly to change?
Can you write the full version please
Barış Özer
Hi @Tauwa
If matches: I changed the part.
Is it correct ?
Rajesh Ramankutty
You can write JQL and Add Filter Subscription to it.
Barış Özer
Is it done with automation?
Can you write sample code for JQL please?
