Hi All.
I was able to create an automation to create a task with a due date of the first day of the following month using the following formula in the due date field: {{now.plusMonths(1).firstBusinessDayOfMonth}}
However, I need to do the same thing but to create a due date for the second, third and fourth business day of the following month.
I tried this, but it gave me an error: {{now.plusMonths(1).secondBusinessDayOfMonth}}
Anyone know how to get this done?
Hi @Aaron Corbin and welcome to the community!
There are only two options for ...BusinessDayOfMonth - first or last. So you'll need to perform an additional calculation against it. I haven't verified myself, but you could try this:
{{now.plusMonths(1).firstBusinessDayOfMonth.plusBusinessDays(1)}}
If that doesn't work, you could try capturing the first business day as a variable and then the second business day as a variable off of that. Something like this:
varFirstBusinessDay: {{now.plusMonths(1).firstBusinessDayOfMonth}}
varSecondBusinessDay: {{varFirstBusinessDay.plusBusinessDays(1)}}
Thanks for the quick response. I will try this out!
For the second option, how would you enter the two variables into the due date field?
You would only enter the second variable...
{{varSecondBusinessDay}}
Just to clarify, for the second option, would you enter this:
or this:
{{{{now.plusMonths(1).firstBusinessDayOfMonth}}.plusBusinessDays(1)}}
Yes - That makes sense for the second option. Eliminates the need for the second variable.
Learn more
