Hi Lars,
I understand that when you navigate to a page such as https://admin.atlassian.com you see two organizations with the same name. This most commonly happens because a previous Atlassian Cloud site with the same name has been deleted. When an Atlassian Cloud site is deleted, the organization associated with that site is not automatically deleted.
I took a closer look at the URL of your cloud site, and I can see that it there has been at least 1 other site by that name in the past that has been deleted.
By default, when you create a new Cloud site, the organization name will default to the same name as the site.
There are two ways to deal with this:
1) rename one of organizations
2) Delete one of the organizations
Only organization admin can do either of these. Any org admin can rename their org. However in order to delete an org, there can't be any active sites associated with that org, nor can there be any claimed domains, or other configurations set in that org.
As for how to determine which is which, if you hover over the select button for each, you should see a URL in the statusbar (if your browser offers that) that contains a 32 character (plus 4 hypens) string. This string is a unique organization id that doesn't change even in the organization's name does. In your case, your org with the id of 00441769-1b90-19ba-7jc0-dcj23bb872jd doesn't have a site associated to it, so you should be able to delete that organization.
Try that, and let me know if that helps.
Andy
Hello @Lars
I have flagged your post to raise it to the attention of Atlassian team members.
