ERR_CONNECTION_REFUSED forcing jira restart
dinis brazão August 11, 2016
quite often, I am getting ERR_CONNECTION_REFUSED error. then, I need to restart and it gets fine. I am using a postGRE database.
These problems seem to show up when I try to perform settngs tasks. eg - now I am trying to connect Bitbucket to JIRA that last week was working an suddenly stopped to work.
Nic Brough -Adaptavist-
August 11, 2016
What do the logs say when this happens?  And when you're doing the admin stuff?  Check atlassian-jira.log in the <JIRA home>/log directory.
Hi.
Thanks for caring.
The JIRA server is running (as per the response of service jira status).
I am not sure of what  to look for in the logs so I am dumping here a few lines - perhaps it rings you a bell - of the last lines before locking users out:
2016-08-11 19:48:18,039 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.TenantAwareActiveObjects] bundle [com.atlassian.jira.plugins.jira-development-integration-plugin] got ActiveObjectsConfiguration
2016-08-11 19:48:18,967 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.OsgiServiceUtilsImpl] Registering service net.java.ao.atlassian.AtlassianTableNameConverter@fe7acc8 with interface net.java.ao.schema.TableNameConverter and properties {com.atlassian.plugin.key=com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin}
2016-08-11 19:48:18,969 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.OsgiServiceUtilsImpl] Registering service com.atlassian.activeobjects.config.internal.DefaultActiveObjectsConfiguration@c1c1eb78 with interface com.atlassian.activeobjects.config.ActiveObjectsConfiguration and properties {com.atlassian.plugin.key=com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin}
2016-08-11 19:48:18,970 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] onPluginModuleEnabledEvent storing unattached <ao> configuration module for [com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin]
2016-08-11 19:48:18,971 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] onPluginEnabledEvent attaching unbound <ao> to [com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin]
2016-08-11 19:48:18,971 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.TenantAwareActiveObjects] init bundle [com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin]
2016-08-11 19:48:18,971 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.TenantAwareActiveObjects] bundle [com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin] loading new AO promise for JiraTenantImpl{id='system'}
2016-08-11 19:48:18,971 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.TenantAwareActiveObjects] setAoConfiguration [com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin]
2016-08-11 19:48:18,971 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.TenantAwareActiveObjects] bundle [com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin] got ActiveObjectsConfiguration
2016-08-11 19:48:19,023 active-objects-init-JiraTenantImpl{id='system'}-0 DEBUG dinis [c.a.activeobjects.osgi.TenantAwareActiveObjects] bundle [com.atlassian.jira.plugins.jira-dvcs-connector-plugin] created ActiveObjects
2016-08-11 19:48:19,024 active-objects-init-JiraTenantImpl{id='system'}-0 DEBUG dinis [c.a.activeobjects.osgi.TenantAwareActiveObjects] bundle [com.atlassian.jira.plugins.jira-development-integration-plugin] creating ActiveObjects
2016-08-11 19:48:19,174 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.OsgiServiceUtilsImpl] Registering service net.java.ao.atlassian.AtlassianTableNameConverter@480bf216 with interface net.java.ao.schema.TableNameConverter and properties {com.atlassian.plugin.key=com.atlassian.labs.hipchat.hipchat-for-jira-plugin}
2016-08-11 19:48:19,177 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.OsgiServiceUtilsImpl] Registering service com.atlassian.activeobjects.config.internal.DefaultActiveObjectsConfiguration@f12e6428 with interface com.atlassian.activeobjects.config.ActiveObjectsConfiguration and properties {com.atlassian.plugin.key=com.atlassian.labs.hipchat.hipchat-for-jira-plugin}
2016-08-11 19:48:19,180 active-objects-init-JiraTenantImpl{id='system'}-0 DEBUG dinis [c.a.activeobjects.osgi.TenantAwareActiveObjects] bundle [com.atlassian.jira.plugins.jira-development-integration-plugin] created ActiveObjects
2016-08-11 19:48:19,189 active-objects-init-JiraTenantImpl{id='system'}-0 DEBUG dinis [c.a.activeobjects.osgi.TenantAwareActiveObjects] bundle [com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin] creating ActiveObjects
2016-08-11 19:48:19,189 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] onPluginModuleEnabledEvent storing unattached <ao> configuration module for [com.atlassian.labs.hipchat.hipchat-for-jira-plugin]
2016-08-11 19:48:19,192 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] getService bundle [com.atlassian.labs.hipchat.hipchat-for-jira-plugin]
2016-08-11 19:48:19,192 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.TenantAwareActiveObjects] init bundle [com.atlassian.labs.hipchat.hipchat-for-jira-plugin]
2016-08-11 19:48:19,192 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.TenantAwareActiveObjects] bundle [com.atlassian.labs.hipchat.hipchat-for-jira-plugin] loading new AO promise for JiraTenantImpl{id='system'}
2016-08-11 19:48:19,192 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.TenantAwareActiveObjects] setAoConfiguration [com.atlassian.labs.hipchat.hipchat-for-jira-plugin]
2016-08-11 19:48:19,192 pool-34-thread-1 DEBUG dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.activeobjects.osgi.TenantAwareActiveObjects] bundle [com.atlassian.labs.hipchat.hipchat-for-jira-plugin] got ActiveObjectsConfiguration
2016-08-11 19:48:19,247 active-objects-init-JiraTenantImpl{id='system'}-0 DEBUG dinis [c.a.activeobjects.osgi.TenantAwareActiveObjects] bundle [com.atlassian.jira.plugins.webhooks.jira-webhooks-plugin] created ActiveObjects
2016-08-11 19:48:19,248 active-objects-init-JiraTenantImpl{id='system'}-0 DEBUG dinis [c.a.activeobjects.osgi.TenantAwareActiveObjects] bundle [com.atlassian.labs.hipchat.hipchat-for-jira-plugin] creating ActiveObjects
2016-08-11 19:48:19,301 active-objects-init-JiraTenantImpl{id='system'}-0 DEBUG dinis [c.a.activeobjects.osgi.TenantAwareActiveObjects] bundle [com.atlassian.labs.hipchat.hipchat-for-jira-plugin] created ActiveObjects
2016-08-11 19:48:19,303 pool-34-thread-1 INFO dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.j.p.hipchat.service.HipChatPluginLauncher] HipChat Plugin launched successfully
2016-08-11 19:48:19,397 pool-34-thread-1 WARN dinis 1187x600x1 qey971 89.114.53.112 /rest/plugins/self-update/1.0/ [c.a.upm.selfupdate.UpdateController] Installed UPM update
2016-08-11 19:48:21,145 http-nio-8303-exec-19 INFO dinis 1188x709x1 qey971 89.114.53.112 /rest/plugins/1.0/com.atlassian.upm.atlassian-universal-plugin-manager-selfupdate-plugin-key [c.a.plugin.manager.DefaultPluginManager] Disabling com.atlassian.upm.atlassian-universal-plugin-manager-selfupdate-plugin
2016-08-11 19:48:21,315 http-nio-8303-exec-19 DEBUG dinis 1188x709x1 qey971 89.114.53.112 /rest/plugins/1.0/com.atlassian.upm.atlassian-universal-plugin-manager-selfupdate-plugin-key [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] onPluginDisabledEvent removing delegate for [com.atlassian.upm.atlassian-universal-plugin-manager-selfupdate-plugin]
2016-08-11 19:48:21,375 http-nio-8303-exec-19 INFO dinis 1188x709x1 qey971 89.114.53.112 /rest/plugins/1.0/com.atlassian.upm.atlassian-universal-plugin-manager-selfupdate-plugin-key [c.a.plugin.loaders.ScanningPluginLoader] Removed plugin 'com.atlassian.upm.atlassian-universal-plugin-manager-selfupdate-plugin'
Get Certified! ✍️
