×Hello,
I'm getting this error during my Pre-Migration checks; see the error below. I can't find the JCMA 135 error code on the support page. Have anyone run into this and can point me to the docs?
ERROR CROSS-PROJECT-DATA project-export Board 'Dev board 1.9.3' is referring to an in-existed saved filter ID: 44570. [JCMA 135] Configure an existing filter for this rapid
Thank you,
Hao
Doing some quick searches it can be a port communication error but I don't think that is the case. I have come across a similar JQL board filter error.
Review the actual filter: if it is referencing two projects and one of them is not included in your migration then the error occurs. Review the filter then copy the filter for this board to MS Word or Note Pad or write it down and then delete it.
After both projects exist in the cloud then you reinstate the filter and multi-project board.
Another reference is this board
