There is an error below.
2021-04-09 16:44:17,719+0900 NodeReindexServiceThread:thread-0 INFO [c.a.j.index.ha.DefaultNodeReindexService] [INDEX-REPLAY] Node re-index service is not running: currentNode.isClustered=true, notRunningCounter=216, paused=true, lastPausedStacktrace=java.lang.Throwable
at com.atlassian.jira.index.ha.DefaultNodeReindexService.pause(DefaultNodeReindexService.java:215)
at com.atlassian.jira.util.index.CompositeIndexLifecycleManager.reIndexAll(CompositeIndexLifecycleManager.java:62)
at com.atlassian.jira.util.index.CompositeIndexLifecycleManager.reIndexAll(CompositeIndexLifecycleManager.java:51)
at com.atlassian.jira.web.action.admin.index.ReIndexAsyncIndexerCommand.doReindex(ReIndexAsyncIndexerCommand.java:27)
at com.atlassian.jira.web.action.admin.index.AbstractAsyncIndexerCommand.call(AbstractAsyncIndexerCommand.java:63)
at com.atlassian.jira.web.action.admin.index.ReIndexAsyncIndexerCommand.call(ReIndexAsyncIndexerCommand.java:18)
at com.atlassian.jira.web.action.admin.index.AbstractAsyncIndexerCommand.call(AbstractAsyncIndexerCommand.java:26)
at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:533)
at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:491)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at com.atlassian.jira.task.ForkedThreadExecutor$ForkedRunnableDecorator.run(ForkedThreadExecutor.java:216)
at java.lang.Thread.run(Thread.java:823)
Why does it happen?
Hello, I give you this link that seems to be the error that is presented to you, it is a known error and there is a workarround on the link
I have the same problem. But none of the workaround specified in JRASERVER-72125 is not applicable to me. Because all of the 4 nodes give the same error and I don't have any index-snaphot. There should be a manual way to force a node to start indexing. Are there any other recommendations?
@ Deniz: I believe you need to stop all nodes except one, run full reindex on that node and then bring back the rest of the nodes. If it is still an issue, then copy of index from that running indexing (when done) node to rest of nodes is in order, followed by restart.
Helped our company's JIRA.
Register today
