I'm having issues with the earliestUnreleasedVersion. The filter is showing the previously released and the upcoming release version. Did something change? I need it to only show upcoming release version. Not both.
project = xx AND fixVersion > earliestUnreleasedVersion
If you only want to show the issues in the upcoming release, your filter should be like this (with = instead of >):
project = xx AND fixVersion = earliestUnreleasedVersion()
Hope this helps!
Thanks for the reply. If i change it to (=) the filter does not show the patches. It skips to the major release 1.13. My releases are set up like this,
Patch Release 1.12.2 Release Date: Feb 15, 2023
Patch Release 1.12.3 Release Date: March 01, 2023
Major Release 1.13 Release Date: March 26, 2023
Any thoughts?
Hi @Sharon Youmans,
EarliestUnreleasedVersion() is designed to retrieve only one version: the one that is scheduled next. The tool is not aware of what you consider as major versions or patches.
I am not sure what it is exactly that you are trying to get as a result. But if you would like to find all 1.12.x versions, you could search like this:
fixversion ~ "1.12.*"
That should retrieve all versions starting with 1.12.
A few additional variations that may be interesting to consider:
fixversion IN unreleasedVersions()
That one should show any unreleased versions, similar to this one (which takes the earliest unreleased version into account):
fixversion >= earliestUnreleasedVersion()
It's still shows boty, the upcoming patch and major release. Instead of only displaying Patch Release 1.12.2. It's showing Patch Release 1.12.2 and Major Release 1.13.
Is it not recognizing the patch as it's own single-version release?
