I have installed the add-on EAZYBI for Jira. ( SERVER)
I can find multiple reports in EAZYBI free instance.
while coming to my installed instance i can only find few reports available.
is it possible to add the rest.
Hi silva,
You can just Export and them import the reports definitions provided in the FREE instance.
See the following article for reference.
Does it solve your problem?
Regards
Congrats!
Did my answer solve your problem?
If so, consider to mark my solution as an 'Accepted answer'. This will help other people with the same or a quite similar problem to find a solution in a easy and faster way.
In addition, by doing this the post will automatically gain the "Solved:" prefix in search results to indicate other people that no further support is needed.
If not, please reply to your initial question to explain us how the issue was solved, you can also mark your own answer as a an 'Accepted answer'.
Kind Regards.
Hey everyone! Are you ready to make a difference? Join the Atlassian Social Impact Bingo event! ❌⭕
Play Bingo! 🙋🏻♂️Online forums and learning are now in one easy-to-use experience.
