Category: ABC1, ABC2, ABC3...ABC9. There are around 8 to 9 category.
How can I plot Bar chart or Table by using Category (Dimension) vs Issue Created (Measures)?
There is only option for status category (To do, In progress and Done) but I am looking for Issue category(Custom field) marked in Red box in above screenshot.
[jira.customfield_10044]
name = "Issue Category"
data_type = "string"
dimension = true
Hi @[deleted],
Have a look at the import configuration of the account you imported the issues into and check out the custom fields settings.
It seems as if the category custom field is not being imported. Locate the category field there and import it as a Dimension. If that goes well, the dimension should appear under Custom Fields, where you see Customer and Vehicle Name.
As soon as it appears there, you should be able to select it as a dimension for your report and display the Issues Created measure by category.
Hope this helps!
Thank you @Walter Buggenhout
Tried that too. It is not appearing in custom field setting as it the locked field, checked from Jira settings>issues>custom field (See the below screenshot)
Is this the category field from Jira Work Management? If so, then maybe importing this into EazyBI is not supported yet (it is a fairly recent feature).
