EazyBI average age from statuses
Colm McGrath
Hi All,
Looking for something like this:
CASE WHEN [Measures].[Issue Status] = 'To Do'
THEN
[Measures].[Days in transition status] /
[Measures].[Transitions from status]
END
That's not correct but what I am looking for is:
  1. The average time it takes for an issue to go from "To Do" --> "In Progress"
  2. The average time it takes for an issues to go from "In Progress" -> "Resolved"
I need these two plus issues created on a chart.
I can get the issues created along with average time to resolution showing on one but I need the custom code to get get the above on that same chart.
Any help / Ideas would be greatly appreciated.
Colm
eazyBI Support
November 1, 2016
Hi Colm,
you can use standard calculated measure "Average days in transition status" together with particular transitions to get average days spent between those transitions.
Create two calculated measures using a tuple from this measure and particular Transition dimension member. Example for average days spent for To Do -> In Progress:
[Measures].[Average days in transition status],
[Transition].[To Do => In Progress]
Then use those two measures and measure "Issues created" in columns together with needed dimension in Rows and Pages.
For further questions or report elaboration, please, contact support@eazybi.com .
Ilze,
eazyBI Customer Support Consultant
Sarath March 26, 2019
Hi, what does this mean?
"To Do => In Progress"
Martins Vanags_eazyBI
This seems the error due to copying the code into Atlassian Community page and converting special characters
Try using this code instead:
This would describe the transition from "To Do" status to "In Progress"
Martins / eazyBI support
Like # people like this
Na
April 27, 2021
If I need to measure average working time from when a task is in progress until it is solved, taking away the time you spend in an impeded or blocked state
[Transition].[In Progres-->Resolveds] - [Transition].[blocked]
