Sign up Log in
Edit Asset Object Integer Attribute via Automation
Kurtis
I'm trying to create a submission form that will allow users to submit asset quantity updates. This involves an automation that will update the quantity based on the submission.
The issue I face is the automation throws an error when trying to update the object attribute which is an integer. I'm not sure why this is occuring and I'm hoping someone can help me resolve the issue.
Attribute value is not valid on Objects DO-3856 (Quantity = 1 )
Error updating Object(s)
Kurtis
Nevermind, I figured it out.
I had to use the "FLOOR" operation to ensure the value stays an integer.
{{issue.customfield_10194.floor}}
JCameron
Thank you for posting the answer. This isn't documented anywhere and I was getting really frustrated. Docs only talk about asNumber, and my helper test in the automation widget suggested to submit a string (which failed). This worked.
Upcoming Jira Events
