When you click edit on an issue, the pop up box that appears for you to edit the details in is not full screen and does not allow you to make this bigger.
Is there a way to make this bigger?
Hi Steph,
Since customers cannot perform any code customisation into OnDemand plafform, I'm afrad that isn't possible. Maybe into a fully customised on premise instance you'll be able to do that.
Lucas Lima
