×Owner of the filter query left the team. I'm a board admin, unable to see 'Edit filter Query' option' Kindly assist. Thanks
Welcome to the Atlassian Community
You can ask Jira admin to change the filter JQL query. He will do it for you
Hello @Devi Mahalingam
Welcome to the community.
Are you able to see the name of the filter? If so, you should be able to bring up the filter to see the details. You can then make a new filter based on that one and change the new filter as you need. Then you can change the board to use the new filter you created.
Or, you can contact the Jira Administrators for your instance and ask them to change the owner of the existing filter to you.
@Devi Mahalingam As you are part of admin , please click on issues search -> manage filter -> search for the filter. After opening the filter , click on edit then you set the option who can edit and view the filter.
The author said they are a board admin. What you suggested is available only to Jira Admins.
