×Hi community,
Anyone know why edit issue with additional fields failed recently?
{ "update": { "Approvers" :
[ { "set": { "id":"xxxx" } } ] } }
The purpose is to overwrite the existing Approvers field value with "xxx", but add additional approvers.
YY Bro
Hi @YY Brother
How did it fail? Would you please show an image of the audit log details, or did it fail when you were trying to create the rule?
And...is the Approvers field for issues or something else? Perhaps check to confirm you have the correct smart value, or try the custom field id: https://support.atlassian.com/cloud-automation/docs/find-the-smart-value-for-a-field/
Finally, although I haven't seen an open defect with update / set for this field, I wonder if using the "fields" syntax with the JSON will help as you want to overwrite the value.
Hi @Bill Sheboy @John Funk ,
Thanks for your help. Below are the screenshots about the rule and log:
It worked before, but failed recently. It's for JSM Change Enablement scenario with approval. The related field is Approvers.
Yong
I am unclear how that could have worked if the field was always a multiple-select, user field, and now has suddenly stopped working with no rule changes.
Let's try the fields syntax to set the field in one step:
"fields": {
"Approvers" : [
{ "id":"xxxx" }
I used Edit issue with Approvers field directly to make it go ahead.
Hi YY,
Do you want to override or add?
To add, follow this format though it is for a group picker field.
"update": {
"Approver groups": [{
"add": { "name": "{{triggerIssue.Group Single Picker}}" }
Hi John, I want to override the existing approver.
