Hello Team,
I would set the permission of my users in way to allow the Issue - Edit grant only to Assignee and Reporter of the specific issue. Could you show me how it's possible to customize it ?
Thanks a lot.
Marilù
Hi @Marilu_ Sorrentino ,
You can do this using, permission schema. You can add only reporter and current assignee to edit permission.
Please refer below link for more details.
https://confluence.atlassian.com/adminjiraserver/managing-project-permissions-938847145.html
Hello @Marilu_ Sorrentino
Welcome to the community.
Are you a Jira Administrator for your instance? Only a Jira Administrator will be able to make this change.
To make this change the Permission Scheme assigned to the project will need to be modified. The Permission Scheme may be assigned to multiple projects. If it is changes made to it will affect all the projects to which it is assigned. If you need to affect limited projects then you need to make a new Permissions Scheme with the permissions you want and assign that to the target projects.
Within the Permission Scheme you would edit the "Edit Issues" permission to grant the permission only to Reporter and Current Assignee.
Here is the documentation link for managing Permission Schemes:
