Sign up Log in
Edit verus remove status from workflow
ADM Amar Msaid
I am working with inactive workflow.
when i attempt to edit (modify) a status i see this message : This status is used in other workflows, editing it will affect them.
when i attempt to remove the status i see this message: Are you sure you want to remove the status 'To Do' and delete the related transitions?
what will happen if i remove this status from the inactive workflow i am editing? will other workflows that use this status be affected?
my need is to remove the status from the workflow i am working in and i don't want the other workflow to be affected.
what is the relation between status ans workflow ?
thank you.
Jack Brickey
April 3, 2023
Removing the status will not have any effect on anything other than the workflow you are editing. However, if you edit a status that is used in other workflows it will change for all workflows. If you wanted to say, rename a status, then the proper way to do that, without impacting other workplace is to simply create a new status and remove the old one.
ADM Amar Msaid
Thank you.
