Editing Multigroup picker Jira smart values - Not working
panjo
July 19, 2024
I'm following this solution, I am doing exactly as suggested -
https://confluence.atlassian.com/jirakb/how-to-add-values-to-a-group-picker-field-using-automation-for-jira-1384127113.html
However, I get the following error:
(Operation value must be an array of group objects (customfield_xxxxx))
Any ideas?
Thank you in advance
2 accepted
Julien Rey
July 29, 2024
Hi everyone,
The original KB article mentioned in this discussion was incorrect and incomplete, so I archived it and wrote a new KB article describing various ways to write a rule meant to upgrade a Multi Group Picker field, using either:
  • explicit values
  • the content of single group picker fields
  • the content of multi group picker fields
Can you take a look and let me know if you are facing any issue with the solutions mentioned in this article?
Here is the link to new article: https://confluence.atlassian.com/automationkb/automation-for-jira-various-methods-to-update-a-group-picker-multiple-groups-field-1416566430.html
Tim Kopperud
July 31, 2024
Thanks @Julien Rey, for updating the incorrect article so swiftly.
TimK
Like 2 people like this
Julien Rey
July 31, 2024
Hi @Tim Kopperud
You are very welcome.
By the way, I realized after writing this KB article, that some of the solutions (using a JSON expression) described at the end of the article will not work if one of the source multi group field is empty.
Since I was not able to figure out a JSON expression that will address the situations where one of the multi group field is empty, I added a warning next to these solutions (saying Only works if both multi group picker fields 1 and 2 are not empty), so please be aware.
July 31, 2024
Hi @Julien Rey
What are your plans to update your KB article to handle the possibility of empty field values for the additions / removals with the dynamic JSON, beyond the disclaimer added at the end of the article?
If the article cannot describe those changes, please consider removing that suggested solution to potential user errors.
Kind regard,
Like Julien Rey likes this
Julien Rey
August 6, 2024
@Bill Sheboy
You're right. I think it's best to just remove the solutions that don't work in the case where one of the source multi group field is empty, to avoid any potential errors.
I just updated the KB article by removing the solutions that don't work in this case.
Thanks for your suggestion.
Cheers
Julien
Tim Kopperud
July 20, 2024 edited
Hi @panjo, welcome to Atlassian Community.
You might try to replace set with add, something like this:
"update": {
"customfield_16209": [{ "add": { "name":"JG-Risk.Amsterdam" } }]
TimK
Tim Kopperud
July 22, 2024
I was able to reproduce the same error using set, and then got the rule to work replacing it with add.
I did not test using . (dot) in the group name though (ref comment from @Marc - Devoteam below).
TimK
Tim Kopperud
July 26, 2024 edited
Hi @panjo , where you able to get this to work?
This worked for me:
TimK
Tim Kopperud
July 26, 2024
Hi @panjo, I now also tested using . (dot) in the group name, and it still works fine.
TimK
Tim Kopperud
July 31, 2024
@panjo, according to the updated documentation replacing set with add, as in my suggestion above is a correct approach, ref:
If you find my answer valuable, it would be helpfull if you mark it as accepted.
Solution 1 in the article is in my opinion a better approach if you don't need to dynamically use other smartvalues and/or smartvalue logic to add to the field.
TimK
Marc - Devoteam
July 19, 2024
Hi @panjo
Welcome to the community.
Can you show your automation and the details of the rule?
This will greatly help members on the community, to help you out.
panjo
July 19, 2024 edited
Thanks for reaching out
Here's a screenshot. Thank you
Like vasanth likes this
Marc - Devoteam
July 22, 2024
Hi @panjo
Is this custom field of the type group picker and are you sure the group nae is correct.
To my knowledge group names can't contain dots.
Register Now
