Editing a Greenhopper (Jira Agile) simplified workflow
Deleted user September 9, 2013
One of our Jira projects is using a Greenhopper simplfied workflow. The project is associated with many boards.
Is thre a way to add a step/status to the workflow? It seems that you can add a step/status and it maps to every status out of the new step/status, but none of the other steps/status map into the new step/status.
How can we edit this? do we have to copy, edit and then reassociate?
Thanks.
Ben
Suresh Kumar October 20, 2014
Is there possible solution to add new template in Agile Board project creation?
Or Can we configure customized JIRA agile workflow scheme as DEFAULT instead of JIRA Agile Recommendard ot JIRA deafult?
TJ Baker
I'd like to know this too .... have you happened to find a solution yet?
darylchuah
September 9, 2013
Hi Ben
Yes you can still do the editing on the simplified workflow itself using the usual step which you had already mention copy, edit, reassociate it.
You can refer on this discussion here https://answers.atlassian.com/questions/182959/greenhopper-simplified-workflow-and-transition-screens
Hopefully it helps :)
Thomas Schlegel
Hi Ben,
you add a status to a simplified workflow by adding a new column to your board. Look here: https://confluence.atlassian.com/display/AGILE/Configuring+Columns#ConfiguringColumns-AddinganewStatus
Cheers
Thomas
Let's build A Rovo Agent 🤖
Save your spot
