Editing velocity templates, what is the Custom Field Id for 'security level'?
glennrees
This article explains how to add a permanant custom field to batched email notification templates in Jira 8.5. However the field I want to make permanant for all emails is the 'Security Level'. This field is used as part of the Issue Security configuration. It is not a traditional custom field however, its a system field of some kind, so it does not have a custom field ID that I can specify as per the article. Any suggestions how I may be able to do this?
The article actually says
For example, you can include a custom field that specifies the issue's security level,
but does not indicate how.
Glenn
Nic Brough -Adaptavist-
November 6, 2019
The security level field is not a custom field, it usually means the "level" field built into Jira and implemented by the "issue security" scheme.
From memory, it might be $issue.level.getName() if you want the name of the level in velocity.
