Most of our users create JIRA issues via email and we'd like them to receive an email notification when the ticket is created in JIRA (with the ticket number, etc.). This is order to be able to add content later.
How can we do this with JIRA OnDemand?
I tried by adding the Issue Created event in the notification scheme for the reporter but it doesn't seem to work (as auto-notifications are disabled).
I believe we can't use built-in scripts with OnDemand.
Thanks in advance for the help provided.
Olivier
'Reporter' included in notifications on issue created, changed settings to 'notify me of my changes' . Tested it by sending a new email ISSUE (from outlook) to jira ,but still I didn't recieve any confirmation email in return.
Is there no other way to make it done?. Other configurations may have missed ?
That setup works fine on all the Jira systems I've used recently, as I said on your original question about this.
You'll need to start full debugging - look at logging outgoing mail to see what it's trying to send.
One other nagging doubt as well - your email handler might be binning the emails, have you got "notify users" set in it (if it's one of the standard ones that has that option)
quick clarification,
the 'notify users' option in the email handler refers to whether to notifiy or not any NEW users that may need to be created automatically, IF a submission is received from an email that is not recognized by the system, AND the handler has the 'Create Users' option enabled.
it is not related to the notification of the Reporter on the new submission, that is managed by the Notification Scheme in place for the project receiving the created issue.
Hi Olivier,
I think the correct way to approach this is to enable the 'My Changes' setting to 'Notify Me' and then review the Notification Scheme in use by your project.
By default you will have it set to 'All Watchers', 'Reporter' & 'Assignee' for all events. These are only the default settings and can be customised for the results you prefer. For example, maybe 'All Watchers' is only necessary when 'Issue Update' occurs and could be removed from other events. The notification customisation is flexible to allow you to choose when and who receive these alerts.
Paul
If you include "reporter" in the notification scheme on the "issue created" line, then Jira sends the reporter an email when they create the issue (including the issue ID and some detail).
It removes the reporter from the list of recipients if they have the "do not email me on changes I have just made" flag set on their account.
Hi zezeto, I think his problem is similar to mine so I'll state an example for you.
1. I create an Issue in jira
2. The issue is created via email (ex address : me@company.com)
3. When jira received my message (which in this case the issue), I expect jira to send me back an information containing: acknowlegement message to the issue i've created, issue number.
Hope this is clear
It work like this in link
https://confluence.atlassian.com/display/JIRA052/Adding+a+Custom+Event
And to know more for jira https://confluence.atlassian.com/display/JIRA052
Thanks for the input.
I tried adding a custom event for the issue creation. The problem stays the same, notification is not sent when user's profile preferences "MY changes" is set to "Do not notify me".
And if we have to set this, then all changes wil be sent too...
Hi
Can you explain with more detail examlpe?
add it in the post function
Learn more
