This is for Jira Cloud.
In our Service Desk projects, we use one of the default Automations to re-open a Closed or Resolved issue if the customer responds to an email thread from that issue.
I want to do the same thing in other (non-Service Desk) projects, but the automation tools are completely separate, just to keep things interesting.
Is it possible to duplicate that behavior somehow in a Jira Software project? I was not able to find anything in documentation or other users' issues.
Thank you for any suggestions.
Hello @Brian Oconnell
Thank you for reaching out.
Per your description, I understand you have an automation rule to reopen a ticket when a customer add any comments (Through e-mail), however, you want to apply this same automation to several projects instead of having to create a new rule for every single project you want. Is that correct?
Today, Jira Service desk has two automation tools:
1 - The deprecated SD automation (Project settings > Automation)
2 - The Automation acquired from Codebarrel (Project settings > Project Automation), which will replace the SD automation as soon as it gets updated with all it's features.
The first tool is project-related and only applies to service desk projects, while the second one applies to any project types and can be configured as project-related or a Global, where you would be able to select it to be applied for several projects at the same time.
That being said, I believe the best option you have to achieve your need would be to create a new Global rule and apply it to any projects you want. This would be the steps:
The rule above will properly reopen your issue when any comments are added (Through E-mail or any other channels).
P.S: Although the issue can be triggered when it is in any "Done" status of your workflows, the issue can only be transitioned to a single status with the automation. That being said, you must configure this "Common reopen" status in all your projects which will be applied with this rule, also configuring a valid transition to move the issues from the done status.
Let us know if this information helps.
Thank you Petter.
I wish the documentation addressed the two different automation tools and when to use each. It's very confusing right now, and this is the first time I have seen anything about plans to deprecate one of them. Maybe if users were aware, they would stop building in the soon to be deprecated system.
