I have a user who receives a daily email with results of a search filter, and they now want to be able to import the contents into another system. Obviously the standard JIRA output format doesn't make that very easy.
I know it's a long shot, but is there any way to get filter results emailed to users in an alternative format, such as Excel/.csv, that would be easier to manipulate?
Many thanks,
Jodie
Hi @jhaughton,
You can definitely do it with the combination of Better Excel Plugin and Excel Automation Plugin, and it's not even a long shot :)
Here you find more on how it would work and this tutorial video shows it in action.
Full disclosure, I'm proudly working for Midori, the developer of Better Excel and Excel Automation Plugin.
Thanks for the mention, @Jack Brickey!
Automatically - not w/o an add on app (maybe Better Excel Plugin)
Manually - certainly. Just create the desired filter query, export to CSV
Hi Jack, many thanks for the speedy reply! The business users are looking at automatically only, and I had a feeling a plugin would be the only way...but because I've only just taken on our Jira system I just wanted to check :)
