I'm trying to enable Tempo in my JIRA OnDemand account. I was looking into this tutorial:
https://tempoplugin.jira.com/wiki/display/TEMPO/Enable+Tempo+in+Atlassian+OnDemand
but the problem is I don't see administration panel, in Issue, Enable/Disable Tempo. Actually I have other type of panel, that is looking there.
Where do I have to look for it?
Yes, I've done that. And went I'm going into Configure, I receive a message, that says:
Please contact your JIRA Admin to enable Tempo Timesheets.
But I'm the JIRA Admin. It's confusing. And I have the link "How to to enable Tempo Timesheets ", But this is sending me again where I have the first problem. and I don;t know where to take a look to disable/enable button
Hi Diana,
Please visit this URL: YOURSERVER/secure/admin/TempoEnable!default.jspa
You should be able to enable Tempo from there
This doesn't help
Hi Diana,
Alex is correct. Go to Administration -> Add-ons, Tempo Timesheets, there you have the possibility to Enable/ Disable Tempo.
Kind regards
Susanne (Tempo)
Probably you're on a new JIRA version, try "Search JIRA admin" on the top left, or press <.> or press <g><g> and type your what are you looking for "tempo". As far as I remember you can enable\disable it from the addons page - manage addons.
