×Hi,
we're using JIRA 7.8.1. and currently I'm struggling with field security. I set-up on every workflow status property 'jira.issue.editable' = 'false' in order to restrict edit permission for more users. Users can change the field values in transition.
However I'm not able to add attachment or create sub-task while status is not editable....could you please advise some workaround?
Petra
We have the same issue when we want to lock a ticket for edit changes at a specific status. At that point we are no longer able to add links are sub-tasks. I can understand the sub-tasks, but links are critical for plugins like Xray.
Yes. We have also observed the same issue. When we add 'jira.issue.editable' = 'false' property, attachment, Assign , Create sub-task operations are getting disappeared.
We are not able add the attachment by transition also ('jira.issue.editable' = 'false' is in the destination status). But we can change assignee using transition.
Alternatively you can use below property.
key: jira.permission.edit.group
value: none (or just another text - not matching any group).
Refer below link for more details.
