Hi Community,
Is it possible to enable/disable (outbound) mail functionality without restarting a Jira instance?
I need this functionality to be able to turn mail functionality on or off as needed in my staging environments. I would prefer to be able to do this via REST API but haven't found anything about it.
Thanks, Rolf
Hi @Rolf Lader ,
you can go to Administration > System > Outgoing mail and disable it from there.
- Tessa
Thank you very much for your reply.
I am serching for a remote operation. A REST API call or something similar, because I want to make this function controllable from outside for my staging environments.
Best regards, Rolf
Apologies, my response was only to your first question.
I do not think this is possible with REST, no.
- Tessa
