Enabling/displaying releases panel on a specific project/issue type
Linda Hoff
I just installed the LaunchDarkly plugin and for some projects the releases panel shows up, as expected. But in other projects/issue types it does not show up.
The only thing I could find in the documentation was to enable "Release" functionality for the project. I've done that but it still doesn't show up.
The screenshot shows the project where it works:Screenshot 2025-07-28 at 14.29.17.png
Any idea or suggestions for how I can have the releases panel in ALL projects and ALL issue types?
2 accepted
3 votes
Linda Hoff
Issue is now solved!
I added the "Development" system field to the layout. That was the thing that was missing.
Tomislav Tobijas
Hi @Linda Hoff ,
Thanks for sharing the resolution! (apologies, I was on vacation, so I'm just catching up and clearing emails and notifications)
Glad you got it figured out 🙂
Tobi
Like Linda Hoff likes this
Tomislav Tobijas
Hi @Linda Hoff ,
Can you share a few more details about the configuration of project(s) where this field is visible and where it's not?
Questions like:
  • Have you checked work item layout in project settings?
  • Have you checked permissions for each project? I'm not sure if this field is connected with "Resolve Issues" permission in permission scheme.
  • Have you checked field configuration?
Where "Releases" field is not visible, can you still see other "Development" fields/options?
Tobi
Linda Hoff
  • There is no field.
  • Layout comparison (not working vs working). In the UI, releases panel is displayed directly under "Development". In the project that doesn't work, I cannot find "Development" to add to the layout (the right column):
  • Project settings (both are the same):
Unless I missed something, according to the page below, it should be enough with enabling "Releases" feature in your project, as in the screenshot above.
https://support.atlassian.com/jira-cloud-administration/docs/integrate-with-feature-flags/
Linda Hoff
Sorry @Tomislav Tobijas , I forgot to answer "Where "Releases" field is not visible, can you still see other "Development" fields/options?"
No, I cannot.
This is what it looks like:
Like Tomislav Tobijas likes this
ENTERPRISE
